Rear Window wont go up | Ford Explorer Forums
Jon d
2002 Sports Trac
the rear window on my 2002 sports trac just stopped goining up today it goes up half way slow and then bounces back dow i took the whole rear cover off along with the access panel did see anything binding up has anyone replaced a motor on one of these? this thing worked perfect yesterday. i got the window up by holding the nob and the up postion bypassing the safety bounce back feature and helping it up on its way to the top. does anyone no where to get one of these motors cheap or for a fair price and where i can get a factory manual or a diagram for the rear window thanks in advance
it isnt the motor. My guess is its the regulator. The cable trolly that moves it up and down. I had to buy a new one through ford 109 bucks. take the motor off (3 screws torx). Try to spin it by hand. If the cables are messed up your better off buying a new assemble. When you pt it back together make sure the window is up and the motor is in the up position. or vis versa down. hope that helps
