justin_b31
- April 14, 2008
- Salt Lake, Ut
- '93 XLT & '02 XLT
So, my story goes like this: Friday night my relatively newly driving 16 year old daughter is taking her 2 siblings (my other two children) to their moms just around 2300hrs.
At some point during the drive my son in the passenger seat tells her that there's a tire problem because of the shuddering of the whole truck, but daughter in her infinite wisdom claims it was the engine shaking.
Well, shortly thereafter the right-front wheel comes flying off at highway speeds and the truck drops (obviously). The truck grinds to a controlled stop and over to the side of the road. (I reinforce slow controlled movements with her at any opportunity in emergencies) I'm happy all went well without further incident except for fixing the truck.
The rotor is toast, it has a flat spot that cuts into about 1/3 of the diameter. The plastic cam assembly and c-clip are done for. I did recover the 4x4 auto hub, but the wheel is MIA; just can't find it.
So, through this miracle of not losing all my kids in one schwoop, I'm think this can be fixed for less than the cost of a cheap-o replacement vehicle.
I have a parts list from Rock Auto, but I am not 100% if this is everything less a wheel and auto hub cam assembly (may do manual hub conversion) from a jy.
Any feedback is appreciated!
1993 Ford Ex pushrod
Brake/Wheel Hub : Rotor
RAYBESTOS Part # 6326R {#106326, 6326} Outside Diameter 10.28" / 5 Bolt Holes Professional Grade Front; RWD B
Brake/Wheel Hub : Spindle Nut Retainer
DORMAN Part # 615073 {#1673324, 3173401, 374536S, 390622S, 4026468200, 6150731, J3173401} 20; Thread Size; 3/4"-16&M20"-1.0; Hex Size: 1-1/16" & 27mm
Brake/Wheel Hub : Spindle Washer
DORMAN Part # 618053 {#E3TZ3B459A} Inside Dia: 1"-1/2"; Outside Dia.: 2-3/16"; Thickness: 1/8" 4WD; Lock Washer; w/Manual Lock Hubs; 3.45 & 4.10 Ratio
Brake/Wheel Hub : Wheel Bearing
TIMKEN Part # SET2 Qty 1 Required Per Wheel, 3/4" bore Wheel Race Front Outer; RWD B
TIMKEN Part # SET6 Qty 1 Required Per Wheel; Includes Timken #LM67048 and Timken #LM67010 Front Inner; RWD
Wheel Lug Nuts
WAGNER Part # BD61281 Wheel Lug Nut Standard Open Nut; Zinc; 9/16" Wheel Nut Length; Front Standard Open Nut; Zinc; 9/16" Wheel Nut Length; Rear
CORTECO Part # 16619 Oil Pan Set MOLDED RUBBER X ENG CODE C
Spindle Bearing and Seal Kit
TIMKEN Part # SBK4 Dana/Spicer 35IFS Axle; Opt. Kit = Brg B2110, Seals 722108 & 722109, & Ring; Front; 4WD
AUTOSPECIALTY / KELSEY-HAYES Part # HB85076 Front Brake Hose; RIGHT
Wheel Lug Nuts
