BobWeiss
- July 27, 2006
- Atlanitc City, NJ
I just finished installing my tranny (A4LD) back into my 91 X and took it out for a test drive. Everything seemed to be fine and all shifts were nice and smooth! After going around the block I pulled it back into driveway and put it in park and tested the fluid level for the 10th time and everything is good.
Next day I start truck and drive to work. On my way in I drive on a major road which you can do 60mph on and the truck still ran great. I even have my OD gear back. (One of the major reasons for rebuild).
At lunch time I go out to take a quick trip and it backed out of the parking spot ok but wouldn't engage in drive. I tried OD, D, 2 & 1 and nothing. I tried reverse again and that worked fine. After messing with this for about 30 seconds I was able to move in 2nd. I then switched it to OD once I got going and it ran fine the rest of the way even if I stopped at a light.
What do you think would cause this? I practically put everything in new. New solenoids, new VB rebuild kit, new OD planets and sprags etc.... The only thing used was the Forward and reverse drums.
Any ideas? I am going to see what it does after work...hopefully it works fine.
Thanks,
Bob W.
Thanks,
Bob W.
