Recomendations for tire size | Ford Explorer Forums
kpgli84
Langley, BC
91 XL
Right now i am currently lifted with a 3" body lift, runnning 32x11.5" tires and 3.55 gears.
this weekend i will be installing a 4" suspension lift, and 4.56 gears. i also have a set of warrior shackles in the rear, and i have F150 spacers (i will only use them to level the truck out if it needs it)
i do not really know what i should run for a new tire size. i either want to use 33x12.5x15, or 35x12.5x15, but i am having a hard time deciding.
what would you guys recommend (and yes i have seached this)
The truck is used as a daily driver, and for weekend offroading. let me know what you guys recommend.
Thanks
If it was me I would go with the 35's, you shouldn't have to much of a clearance issue with a 4" susp & 3" bl, I have 33's with the 3" bl & 2" susp and can't wait to get rid of them and get some 35's, there just to samll for me, may not be for you though, with the 4.56 and 35's you should have no prob as a daily driver. ;)
