REDLINING the explorer......... | Ford Explorer Forums
leenjen
in the poconos, PA
2001 sport
i've been reading a lot of posts where people talk about driving up to 6000 rpm or more in their explorer (even the first genereation OHV V-6). how is this possible?
i have a 92 and it redlines at 4900 rpm.
some people say they feel the most power between 4000-6000 rpm. mine feels strongest between 2500-3500. is my explorer different than everyone else's?
in your reply, could you please state what the redline is at on your explorer? thanks..
leenjen, I'm not for sure on the redline in mine, but I feel the most power in lower RPM's and then at cruising speeds if i get on it hard it'll shift and take off. But once it shifts a couple times taking off hard it doesnt seem to put the right amount of power to the gorund, but then it'll shift again and really start winding it out. The torque is in teh bottom of the powerband and the ponies are up higher if I remember right.
They were probally talking about the V6 SOHC or the V8s
Re: Re: REDLINING the explorer.........
i know the SOHC revs higher. and i dont know about the V-8. but i'm talking about people with the OHV V-6.
maybe mine is different because it has a manual transmission. but i dont think that would affect the engine.
I wasnt expecting this to turn into it's own thread but here goes.
My 93 acts pretty much as you describe but it has an auto that shifts it at about 4000, I can feel the engine start to lay over once I pass 3800. I dont know what type of engine mods you have so it's hard to tell what you should be getting but 2500-3500 sounds like a stock power band. Right after I had the transmission mods done to my 92 I found that the engine would lay over at about 4500 I did some head work in the area of the valve springs and some port and polish work which helped it pull past 4500. The addition of a larger throttle body free flowing air cleaner, exhuast and chip really woke the engine up in the 4500-6000 range.
Now on to the why. Other than the fact that I like to tinker with vehicles I have a 120 mile commute to work on 5 different freeway systems and a few side streets. I like to have the upper end kick when merging into 80 mph traffic from a 55-60mph interchange. (Ever been humming along and have a slow poke get in front of you cause they dont have enough power to get out of their own way?) With my present setup I can cruise along at 75-80 running at about 2000-2100 rpm I can floor it at 60 and nail second gear for a solid pull to about 85 which helps a ton in merging situations in a state where turn signals dont mean much and people try to keep you from changing lanes.
The down side. Due to the 3.08 gears and heavier than stock tires off the line performance sucks. Even with all the mods a stock explorer has no problem getting ahead of me from a stand still start, my only chance is to let the engine get into the power band and hope to catch the other ex.
I've never had my truck on a dyno, nor have I taken it down the 1280. Basically I really dont care to chase the numbers of more rear wheel horsepower and 1280 times, all I've done is make my vehicle a little more usefull for my daily drive. I'm also not making any big power claims, no matter what I do to the OHV it's still in a 4000+lb brick that wasnt meant to go fast even though some do through the application of $$$$.
The bottom line that the stock OHV isnt a high reving engine, it can be made to rev out but it takes some work and some $$$$.
Well, my friend and I had a revving war this afternoon when he pulled up in my driveway. He was in his camry, and I was in my X. I revved it to 5000 repeatedly, seemed fine, but was just very loud. the camry, on the other hand.. well, it was kinda quiet compared to the X :P
BTW, as for revving during driving, my tranny shifts at usually 3000-3250. I think I've seen it tap 4000 once when I really stomped on it during passing and merging.. Other than that, it shifts fairly low. I'd be afraid to be in the X if it shifted at 6000rpm regularly :confused:
I may have given the wrong impression. I dont drive around upshifting at 6000 on a regular basis maybe once every couple of weeks. The highest I go on a daily basis is between 4500-5000 on a long uphill freeway on ramp. But its nice to have the extra range there if I have to move out on the highway.
