Justinwht
- August 12, 2014
- Location
- Rosston and Fort Worth, TX
- Rosston, Texas
- '96 XLT, '96 XLT, '00 XLS
SOLVED.
Been on forum several years and should post info on my three Explorers. '95, '95, 00.
At issue is 2000 4.0 OHV, standard shift, 150K miles. 21 mpg highway and 19 in town.
Few months ago at highway speed, the engine missed once. Last month it missed a few times at 40 mph. Last week it ran rough in parking lot and stalled, but restarted immediately. This week it started missing, drove a few hundred feet and finally stalled in parking lot. Was able to restart and drive home.
Replaced fuel filter, probable the original and fuel in filter was black, yes...black.
Engine starts, good acceleration when I floor it, but when moving slow in parking lot it wants to stall when PRMs drop from normal 800 to 400, so I give it more gas. The stalling at low RPM I found (on this forum) a symptom of sensor problem.
Had the truck a year and Engine light stays on and error code (not recall) said cam shaft position sensor error.
Right now getting several error codes.
P0340 - Defective Camshaft Position Sensor
P1309 - Misfire Detection Monitor Not enabled
P0171 - System Too Lean Bank 1. This may be caused by misfires, and not really a lean fuel problem.
P0174 System Too Lean (Bank 2). Same as above.
P0455 Evap System Large Leak Detected. Might be caused by bad sensor.
All four errors refer back to a cam shaft position problem.
I pulled out the suspect sensor, ohm meter shows 593 ohms; compared to 698 ohms for new one.
WHAT TO EXPECT ...
On SOHC its behind engine on driver side, on OHV on the passenger side. Need 5.5 mm ignition wrench.
As the bolt comes out, the wrench will slip past the head, so use thumb to feel the wrench stays on head.
The sensor wants to rotate when placed back in. The shaft assemble has a keyway that will match the sensor electrical connector and screws holes would be aligned.
SOLVED ...
Engine now idles at 1,400 RPM for about a minute after clutch pushed in, then drops to 900-1,000 RPM. No more stalling when RPM drops to 400 RPM driving in parking lot.
WHAT TO EXPECT ...
SOLVED ...
