with the clifford system installed does your keypad entry still work?
any problems with the stock alarm system?
did you have to tape a piece of a key to your steering column?
also, where does one find the ford remote starter?
That bypas module is required for PATS and newer models. Look at DEI accessories, they have two which can work on Fords. BTW, don't cut the key which will be buried in that bypass module. Good luck,
