I think he means to get power for it. You can wire it into any hot 12 volt wire. If you have an aftermarket deck, there should be a wire on there for it. Or you can just wire it into your fuse panel. I suggest into one of you accesory fuses that are off when the car is off. Your radio fuse is the most obvious one, that way when you radio is on, your amp is on.
