Remote Wire | Ford Explorer Forums
Remote Wire
X2002sportX
Kansas
2002 Explorer Sport
Where are some places I could my amp remote wire up to?
You need to run the remote turn-on wire to the amp so wherever you choose to put your aftermarket amp is where you need to put the wire.
I think he means to get power for it. You can wire it into any hot 12 volt wire. If you have an aftermarket deck, there should be a wire on there for it. Or you can just wire it into your fuse panel. I suggest into one of you accesory fuses that are off when the car is off. Your radio fuse is the most obvious one, that way when you radio is on, your amp is on.
i have found that one of the easiest places was the power to the cigarette lighter.
