Pry out the little piece of trim around the door handle. There is 1 screw behind there. Take out the two screws at the bottom edge of the door panel. Lift out the window/lock switch panel and disconnect wires. Now you can lift the whole door panel up about an inch and then remove. It's quite easy since there are no xmas tree clips anywhere.
