markusm
- October 11, 2012
- Michigan
- 1992 Ford Explorer
I have a '92 Explorer 4WD and want to remove the front left spindle to remove the short axle shaft to replace the u-joint. My problem is: the tiny 6mm bolt that holds the ABS sensor holder is rounded off and is so buried I can't figure how to remove it. I've tried hammering on smaller sockets but no luck. Also, is the ABS sensor attached to the cast-iron bracket or does it simply protrude through it?
