boostranger
- January 20, 2003
- Rio Grande, NJ
- 91 xlt
removing engine, bolt size for torque converter
As i my week could not get any worse. On my way back to Ohio from Jersey on tuesday i blew up the motor in my X, 400 miles from where i was heading. Cost me $400 to get it to school in Ohio, thats $360 more than i had. So now i am stranded in Ohio with no ride. Yesterday i started ripping the engine apart, but of course 20 min after i get started its starts raining and it was like 25 degrees out. Wake up this morn and theres 4 inches of fresh snow on the ground, buts its sunny and warm so its all good. I get everything set up top and its time to crawl under and drop the starter and the torque convertor and the lower bellhousing bolts. Since it was sooo warm there was a huge puddle under the truck, great. So i crawl under and drop the starter and realize that there is no inspection plate so i figure the only way to unbolt the converter is to use a box wrench through the opening for the starter. But since i am doin this with no jacks or anything and its wet as hell out i could not really get a good look into the hole.
Question is what size are the bolts for the converter? Is that the correct way to go about getting them out? How many are there, 3 or 4? hopefully the weather will hold up tomorrow so i can get the converter off and get the motor out and apart to find out what the hell happened.
Thanx in advance for any help or advise.
Jon
Jon
