Removing front sway bar | Ford Explorer Forums
96ExplorerSport
Pittsburgh PA
96 X Sport 4.0L OHV, 4WD
Hi,
In order to get to the steering gear I have to remove front sway bar on my 96 X. Manual suggests jacking up the front end to unload suspension before removing end links. Is this really needed? Can I disconnect sway bar links with loaded suspension? On my other car, I can do it with loaded suspension as long as the car is leveled.
If I have to unload suspension, where can I put jack stands up front?
Thanks
try it loaded there is not much pressure on the sway bars.
I just took mine off and didn't jack it up. You'll know if it's a problem once you start turning the bolts.
