franktank25
- May 4, 2013
- Baraboo, WI
- 1996 Ford Explorer Sport
I have a 1996 Explorer Sport. Shows signs of uneven front tire wear. Upon inspecting the ball joints I discovered that both ends of the front sway bar have broken loose. The ball joints to not appear to be bad. I'm on a tight budget. Would the sway bar being disconnected cause tire wear on the inside of the tire and not the outside. Or should I just replace the ball joints even if they appear to be fine. Help would be greatly appreciated. Thank You.
