Removing third cat temporarily due to bad rattle | Ford Explorer Forums
Davies0202
Blandon
2002 mountaineer 4.6
The third cat on my 02 4.6 mountaineer started to rattle badly so I can assume it’s grenaded itself. If I remove it and replace it with straight pipe for a month or two until I have access to a welder and another cat will I harm anything? I don’t intend to keep it like this but it sounds like my engines gonna blow and I’d rather not drive around it with for a month or two rattling away.
Alright thanks
It won't do anything, except make your exhaust a bit louder.
This includes emission tests. Don't ask me how I know.
Well ya, if there is no sensor after the 3rd CAT then there is no way to trigger a code in the computer that will fail the emissions test. Now areas that don't use the OBDII and use a sensor up the tail pipe there could be a problem...
You can put a spacer between the O2 sensor and the pipe to trick it into seeing different flow than the upstream sensor so it doesn't trigger a code.
This will turn into a permanent temporary solution.
If I’d pass emissions I would, I wouldn’t mind the extra sound
Just an update for anyone in the future no check engine light after about 200 miles engine runs the same if not a little better can’t tell if the extra mpg is me backing off cause its louder or if it’s running better either way nothing bad happened so far.
Theres no harm done in removing the 3rd cat as long as you see no o2 sensors after the cats....IIRC, Ford changed o2 sensor locations twice i believe on the 3rd gens. Alot of the guys with the 4.6 remove the 3rd cats to get a better exhaust note when putting on a performance muffler.
I think what you actually mean is it won’t harm performance. It’ll certainly put out more emissions. And, be a federal crime.
Yer no oxygen sensor after the third cat it’s a few inches before it, on a 2002 mountaineer atleast
Yeah I was gonna replace it but I just dropped $1500 on a transmission rebuild so my exhaust being a tad bit louder doesn’t bother me I already have no muffler haha. I was mostly worried about making my engine run wrong and the exhaust smelling like eggs but honestly it smells the exact same and drives a little better.
You can’t smell a lot of the junk the catalytic converter burns off. It’s surely there.
