replace 6.5 sub with 8 sub | Ford Explorer Forums
rgomez
Does anybody know if I can replace my OEM 6.5 sub with a 8" sub using the OEM stealth Box and without adding a new amp?
thanks
Robert
99 Eddie Bauer
Match Sound system
You're in luck, it's been done! You might have to get in touch with with the person who said he did it in this discussion:
Dead Link Removed
Tips if you buy a new sub, try and find out what the volume of the OEM box is to match a good sub. If you're using the stock sub amp, then you won't have to buy a sub that can handle a lot of power, but spend it on a nice one with a high sensitivity that you like to make the most of your stock amp's power.
Good luck!
[This message has been edited by JTang (edited 01-12-2000).]
