Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
i have been plagued with transmission issues since I bought my 2007 4.0 EX 4x4. I'd even had the tranny rebuilt at 80k mi. Nevertheless I've still had to put up with the 2nd to 3rd shift flare only 18k mi after my rebuild. I went back to the shop after it started to flare again and they replaced the solenoid block. That cured it for 5000 more miles and at that point I was out of warranty and frustrated at the shop. So I lived with the 2nd to 3rd flare for happening periodically. I just recently put larger tires than what ford recommends and I think that pushed the tranny over the edge. My shift flare got worse and more consistent until I corrected the tire size with an SCT x4 scan tuner. I still have the shift flare and the rpms don't jump as high but it flares more consistently. I was convinced they didn't sleeve my servo bores so I tried the aj1e solutions, drove great for a day and then back to flaring. I found some good info about correcting the issue in the transmission forum that pertained to the 5r55E transmission opposed to the 5r55S. The direction I'm headed now is to replace the valve body and the solenoid block. There is such a wide variety of remann VB's and solenoid blocks out there it's hard to know what to buy. With ATF, filter and Bosch parts I could spend around $350-$400 or if I bought Sonnax I'd spend over $700 on those two parts alone and I'm not sure why they charge so much. I can buy a complete remann transmission with the upgrades for$1700-$1800 and I'm wondering if I'd be better off just replacing the whole thing. So if you were in my boat what would you do? Replace the valve body and solenoids or replace the whole tranny?
