Replaced 96k OEM spark plugs today! | Ford Explorer Forums
Nitrous SSC
Layton, UT
98 Eddie 3-oh-2
I'm glad I did the body lift. It made things so easy. I just jacked up the front Crossmember till the wheels were almost off the ground and moved the inner splash shields. It took about 30 minutes if that to change all 8 plugs. What also made it easy was a 3' extention with swivel socket. I could do full turns instead of racheting.
The OEM plugs NASTY! :fart: With the new plugs the truck fired right up without the usual knock I'd get. Also the idle is 10 times smoother.
I was going to do wires but they all looked in great shape.
If your putting off changing your plugs. DO IT! :burnout:
Also while I was working in that area I grabed some stock 5.0 headers just for giggles. The passanger side one could prolly fit. However that drivers side is one big mess of ****. :(
