Replaced Front wheel bearings now | Ford Explorer Forums
qtacclia
louisville, ky
97 explorer sport
I still have a bad vibration on deceleration. I had this before relacing the hubs but it is still there. It is like the four wheel drive is kicking in and out. Pulls hard left. I was getting an abs code replaced the wire and it went away. I am lost now any help would be appreciated.
Which wire did you replace? Is the ABS sensor working properly?
Sensors are all working. No abs light anymore. Iam working on a 2004 explorer 4x4.
I had same problem recently but during acceleration -- it was the 4x4 control module. Easy to replace module or disconnect 4x4 by using brown-wire mod.
If vibration is under deceleration it may be the rear differential but if vehicle is pulling then check front suspension parts - balljoints etc. Good Luck.
