billsyzfr-1
- February 2, 2007
- Cedar Rapids Iowa
- 2002 XLT
I need help in a bad way!! I had a front wheel bearing go bad, replaced with a new, torqued it to 30#. Not sure if that's right torque or not. Noticed that the outer was a little sloppy, and that the sway bar bolt was busted in half. So I ran out and got the sway bar bolt and bushings replaced as well. Was going to hold off on the outer tie rod end until had more time. Well driving it across town and it started wobbling and bouncing... Terribly at 65-70 or so. like I'd left all lugnuts loose. Were tight and limped it home. Figured playing with the outer, I'd made it worse, so I replaced it. Still have the terrible wobble at the higher speeds. I did nothing to cause this I don't think. Any ideas?
