Exproblems
- April 17, 2011
- Orchard Park, N.Y.
- '05 Explorer XLT 4.0L
how about the front is it just as easy?
Yes, just a little different way to change it. No drain plug on the front axle, but there is a "fill plug" that you remove and you have to use a hand or an electric pump to remove the old gear oil. Stick the tubing from the pump into the fill hole as deep as you can get it in the diff and pump away. Once you get all or most of the old gear oil out, reverse the pump setup and connect it to a new bottle of gear oil and pump it in thru that fill plug. Hand pumps allow you to screw the pump right on to the bottle and you run the fill tubing into the fill hole. You can buy them at parts stores for around $8-$10. Pump the new gear oil into the hole and once it starts to backup and run out of the hole, the diff is full, re-install the plug. The vehicle needs to be level when you do this, same for both front and rear. Front diff fill plug torque is 20 ft lbs for a V-6, and 18 ft lbs for the V-8. Rear diff fill plug torque is 25 ft lbs, do not have the torque setting for the rear drain plug. Just don't over tighten it.
