Replacing side view mirrors..Help! | Ford Explorer Forums
hodge500
Huntersville, NC
2001 Explorer Sport
I removed door panel and mirror on 2001 Explorer sport and do not see where to plug new mirror wiring harness.
Where was the wiring for the original mirrors pluged in? If your old mirrors were not wired there may not be a harness there.
What kind of mirror are you putting in?
Replacing driver and passenger side power windows with puddle lights. Same mirrors currently on vehicle. I took bolts out of back of mirror and pulled it out of door and there is no wiring harness. Don't get it. Is it deep down inside door? I pulled wiring that was in door out until it stops and don't see a harness anywhere.
If you dont have puddle lights on your present mirrors there is probably not a lighting harness in the doors.
Yeh I have a harness but I have puddle lamps, with no puddle lamps I believe you'll have to make your own harness setup.
Correct- puddle lamps are not a direct plug and play...
