sirhk100
- December 19, 2000
- las vegas
- '91
So, I'm assuming you all know what engine noise is and sounds like, right? Usually caused by a bad ground or cheap RCA's? Well I've got engine noise but it doesn't matter if the engine is running or not. It gets better, just wait!! This started one day outta the blue. The systems has been in for almost a year. All the components are pretty old ecept for the sub and they have been in a couple vehicles. Check out my sig. for a list. Anyways, here's where it gets wierd. It makes the engine humming noise with the motor on or off with the key in the accesory position. But, it goes away when I turn on my head lights WTF!! Has anyone else experienced this? I've checked my wire connections and grounds and they all seem fine. The only thing that I can still think of is maybe something in the HU failed and when I turn on the headlights it kicks the display over to dim instead of bright for the day and whatever inside is making the noise is affected. Oh, you can also hear it stop when a CD is inserted but as soon as it starts spinning it starts humming again. Does that fact alone mean it's soimething with the HU? You can hear the humming on tuner or CD.
Any ideas would be great.
Thanks,
Khris
Thanks,
Khris
