Reklaw
- September 19, 2014
- Glen Rock, PA
- 2004 Ford Explorer XLS
Ok, I know some of you have read my previous posts about a bad wheel bearing in other threads and it has been replaced but i'm still having the same symptoms.
The start of the problem was a grinding or rumbling noise when I turned my steering wheel to the left. I replaced the front right wheel hub/bearing assembly with a cheap one and it was still noisy as soon as I hit the road. Bought a better wheel hub/bearing assembly and put it on. It seemed like the new bearing I had just put on was definitely loose already when i got it off and it was covered in grease on the inside surface. I thought I solved the problem. Drove around the back roads with no noise for the afternoon. Next morning when I hit highway speeds the noise was there again when i turned the wheel to the left. I know this could be the rear bearing and I have never replaced them but I think it just "feels" like it is from the front of the Explorer. Someone on here, I think @imp suggested that maybe I over tightened the axle nut. This time I made sure that I did not over torque the axle nut and also made sure that everything I put back together was torqued to spec.
I did think, what if it is the cv joint. A few internet searches tell me you will hear a popping if the cv joint in the half shaft is bad. I have looked at the boots on these and they also look fine. I did see some reports that you may see grease all over if it is a bad cv joint. Well, my brand new strut, the sway bar link, and lower control arm on the drivers side looks like it is mud or something. Now i'm wondering if it is really covered in grease and I need a new half shaft on the left side. And then I also remember that There was a bunch of grease on the back side of the bearing i changed out that I thought was from the bearing and i'm wondering if that was from the cv joint instead? Also, I don't know if this has anything to do with my problems but after I got the new hub/bearing put on the other day the abs light was on until I drove it about a quarter mile then it went off. The next weird thing is that when I was turning I felt like it was in 4WD as if the transfer case was kicking in when it should not have been. I currently have the transfer case unplugged and it doesn't feel like it is in 4WD now.
2004 Explorer XLS 4WD with 165k on it. The front wheel hub/bearings were both changed at around 100k 3.5 years ago. I just put Rancho Quicklift Loaded Struts all around the Ex at the beginning of the summer.
What do you guys think my next step should be? Should I jack the rear end up while i have the transfer case unplugged and free wheel to make sure my rear bearing is not bad? Are there any more tests to check or confirm bad half shafts on the front? Your help and thoughts are greatly appreciated.
