Rough Country AAL | Ford Explorer Forums
Rough Country AAL
Pro comps look to be about the same($10 less). Summit only lists them as 91-97. Whats up with that?
One other question tho... Do you need any additional clamps to secure these to the pack?
No, you don't. The extra leaf is installed typically right above the helper spring in the leaf pack. Buttons right back up after you're done like it was still stock.
My Explorer's driver's side add-a-leaf kept swinging in at the front and would often rub against the gas tank skid pate when the rear suspension cycled. Of course a hammer every now and then fixed this problem but a clamp or whatever might help (if you can find a way to get one on there).
