punkrex
- March 24, 2011
- 2005 xlt
I have a very annoying intermittent problem. Basically goes like this, exploder is warm and I turn it off. When I go to start it back up, rpms rise like normal, then drop below idle, to the point of almost dying, the recover to normal idle.
What I have done with no success:
Replace intake manifold gaskets.
Sprayed intake and hoses with starting fluid to try to find air leak.
Cleaned MAFS.
Cleaned throttle body.
Replaced plugs.
Swapped fuel relay with A/C relay.
Seafoamed fuel on last 5 tanks.
85k on 4L flex engine
Replaced fuel filter ~65K (not an easy job :thumbdwn
Recently blew driver's side cat into muffler, replaced both. but problem existed before bad cat...
Cleaned MAFS.
Replaced plugs.
