Rough Idle When cold | Ford Explorer Forums
MM9886
Lambertville Michigan
1998 Mountaineer
Hello, Im having some Idleing problems with my mountaineer. Its a 1998 V6 4.0. When I start my truck in the morning the engine will run fine at about 1500-1700 rpm. After about 3 seconds it acts as if the Choke kicks off. After the motor warms up it runs just fine no problems at all. It has brand new plugs, wires, coil pack, Iac motor, Cleaned the MAF. Im stumped about what the problem could be. Anyone have any Ideas??
EGR not opening?
Did you check the idle air control valve?
