rough idle | Ford Explorer Forums
rough idle
joeburt130
Davis, CA
95 ranger
i have a 95 ranger with a 4.0 v6, and my problem is that i will have a slight rough idle, it idles normally, but every few seconds the rpm will dip down slightly. Wondering what could cause this, or if its just normal operation.
Have you tried all the normal stuff like plugs, wires, Cleaning you MAF IAC and throttle body, and checking for vacuum leaks?
im gona try cleaning my IAC, i had a broken grommet at my brake booster, fixed that, still same problem, my MAF is clean and so is my throttle body
I might also try pulling codes (see stickies in EEC-IV forum) and checking fuel pressure.
i recently scaned for codes and it had nothing, id love to test the injectors but the dumb intake manifold is completely covering them
