Robert
- October 26, 1999
- Location
- CA
- Kelseyville, CA
- '13 Ram 1500 Longhorn
I think I have found the source to my clunking whenever going over bumpy roads. NHTSA's Web-Site lists a couple of TSBs pertaining to the Kevlar patch wearing off of the torsion bar adjusters causing a clunking noise in turns or going over bumps. This is the noise that I have been trying to track down for the last 6 months. I crawled under my '97 tonight and found chunks of hard rubbery material (probably the Kevlar) falling out of the left torsion bar adjuster. For those of you that have replace your torsion bar what is the best method to clamp the adjuster and let it down? I want to pick up a new adjuster Friday and put it in Saturday and am looking for any tips to make it go smoothly. Thanks.
PS: here is the text from NHTSA for those of you fighting the same clunk:
Service Bulletin Number: BC0881961004
Bulletin Sequence Number: 57
Date of Bulletin: 9610
NHTSA Item Number: SB050438
Make: FORD TRUCK
Model: EXPLORER
Year: 1997
Component: SUSPENSION:SINGLE AXLE:REAR:TORSION BAR
Summary: THUMP/CLUNK NOISE IN TURNS OR OVER BUMPS MAY BE CAUSED BY THE KEVLAR PATCH WEARING THROUGH ON THE TORSION BAR ADJUSTERS. *TT
Service Bulletin Number: 13415
Bulletin Sequence Number: 966
Date of Bulletin: 9910
NHTSA Item Number: SB609679
Make: FORD TRUCK
Model: EXPLORER
Year: 1997
Summary: EXHIBITING A SQUEAK TYPE NOISE FROM THE REAR STABILIZER BAR WHILE DRIVING, ESPECIALLY WHEN GOING OVER BUMPS. *TT
Make: FORD TRUCK
Model: EXPLORER
Year: 1997
Make: FORD TRUCK
Model: EXPLORER
Year: 1997
