RTI Scores... | Ford Explorer Forums
RTI Scores...
NightHawk
I went to a local 4x4 shop yesterday and they had an RTI ramp set up so I decided to give it a shot. I scored a 610 with the front swaybar connected and a 680 with it disconnected. I probably would have scored a little bit higher had I let my new Radius Arm Bushings break in a little. I am wondering what some of the other Explorers out there are getting with their different lift kits. Thanks for the info!
Happy Trails!
'93 XLT
4" Skyjacker (suspension)
3" Performance Acccessories (body)
31x10.50 BFG All Terrains (Till next week)
Dyno Max cat back exhaust
Rancho 5000 shocks
Poly bushing kit (front and rear)
More to come!
Well, my lift is not mass produced, but it will give you some idea as to potential. On the 20 degree ramp (probably what you were on as it is the most common), the Beast will score over 1000. On the 30 degree ramp, she will pull a 767. This is with a 112" wb.
Gloria
93 EB Explorer (highly modified)
94 F150 Lightning
WOW!! Dead Link Removed That is impressive! Is that with the TTB front end? Or do you have a solid axle? And what kind of springs do you use? Thanks for the info!
Happy Trails!
'93 XLT
Rancho 5000 shocks
More to come!
Uhh.. Nevermind.. Don't answer that last message.. Just saw your pictures.. (sheepish grin) Thanks!
