RTV on a tranny gasket | Ford Explorer Forums
92 sport
Alpharetta GA
92' sport
Hi,
I'm in the middle of changing a long over due tranny filter and would like to know if I can use RTV black just to hold the new gasket in place. Some things I have read said I can and others said not to. The gasket is cork and was all folded up in the box so it wont sit flat with out some help.
Thanks
Jason--
A little bit just to hold the gasket in place shouldn't hurt anything.
Thank you I just wanted to make sure!
Thanks again
Jason---
You can also use Petroleum Jelly to hold the gasket in place. That is how I do it. Petroleum Jelly is compatible with ATF.
If the gasket won't lay flat, bring it inside where it is warm (or out in the sun if its a warm day) and put it on a flat surface for an hour or so.
