1998rollover
- November 10, 2008
- Weiser, ID
- 1998 Mountaineer
02 Sport Trac with 1998 V8 Mountaineer drivetrain swap.
Went to Subway last night. Got in the truck to come home, started it up and after about 5 seconds it quit.
Checked all the fuses, they're fine. Could smell it's getting gas but zero evidence that it's getting spark.
Recently it's had new coils, new cam sensor, new EGR valve, pipe and the sensor that connect to that pipe, new TPS and IAC. Also installed a new dual row roller timing set last year.
After a bunch of cranking it just stopped. I'm thinking got a cylinder full of gas, so I had AAA haul it home.
This morning I tried again and after about 4 turns over it won't crank. Oil level shows about 1qt low.
No codes in the PCM due to having pulled fuses to check them.
Shouldn't be the cam sensor because these things will run without it. Found the one on my all stock 1998 Mountaineer was broken with the magnet rattling around, still ran. Gets better MPG since I replaced that.
It's long had a problem where the fuel pump fuse corrodes just enough to stop it, so I remove and replace that 50 amp fuse and off it goes again. Still does that despite anti-oxidant silicone grease on the fuse contacts. Has the Sport Trac fuse box underhood. But this time it's not that because it's getting fuel.
