Small drilling required but it is great. I drilled 1 hole in the passenger side floorboard right by the body mount. Slipped the cable through there and ran it on top of the inner fenderwell and I drilled 2 holes right next to each other on the plastic inner fenderwell and put a ziptie around the cable so it wouldnt hit an exhaust manifold or somethin. But the two holes are to tie the cable to the fenderwell. Then run it to your battery. You may want to get something long and flexible, I used a fishing pole. And fish (no pun intended) it down towards where you drilled the hole in the floorboard, put the cable in there and pull it up, then, of course tie it down, but I forgot to mention the fishing pole deal. I hope you get what I mean. Ask me for more questions if you need them. Don't worry about drilling the hole, it shouldn't be big, just somethin big enough to slip the cable through, unless you were running multiple wires, thne you could get a rubber grommett and put it in the floorbard and run the wires through it.
