LOL, any fuel pressure regulator for a 88-93 mustang will work. just get a good aftermarket one thats adjustable, and replace your stock non-adjustable one with it.
understand, im not 100% sure this is gonna work perfect, all im saying is it should work. the general idea is ditch the FMU, go to way bigger injectors, and use both the FPR and a computer tune to have the fuel ratio were you want it from idle to redline. i helped a friend do this without the comp. tune on his mustang, and it worked. but, he got bigger injectors and was running pretty low boost at the time.
with stock injectors, you may have to run the fuel pressure real high. if it doesnt work, hook the FMU back up and turn the pressure down. a good FPR is around $100, and you'll need this sooner or later anyway.
