Running Wires Thru Damn Door Jams | Ford Explorer Forums
Long Island, NY
97 Mountaineer
I was wondering how all of you ran your wires through that cylinder thing on the drivers door. I haven't really looked at it closely but it looks like a pain in the ass. I'm getting two sets of components for christmas so I don't feel like fooling around. Its like 30 degrees out around here. Thanks in advance, Steve
I ahd to do it with mine becuz i didnt ahve teh amp bypass so i had to run all new wires and irememerb it was a pain in the a$$ u have to take off the kick panels and use like a co hanger to pull the wires. ill have to ask my dad becuz hes the one that did it ill get bak wit u lata cuz hes asleep right now
good nite time to goto bed
It is. You just gotta mess around with it until it works
I used the stock wires to power the 5 1/4 woofers. You don't new wire unless you are running a ton of power to them.
Good luck.....
What size wire are you going to run and for what? If its the power cable from your battery to an amp I ran mine through a rubber gromet that was on the fire wall by the steering colom. I have ran them through door jams and it is alot more work then running it through the rubber gromet.
I'm running either 14 or 16 gauge wires to (2) 6 1/2 component sets. Im gonna be running around 60 rms to each channel. I only have to run one wire through each door because I'm gonna mount the tweeters on the A+B pillars.
I've got a thread going on this same subject: Dead Link Removed
Will there be a noticable difference in SQ, when using the stock wiring instead of new 14-16 gauge wiring?
You only need to use bigger wire when you run lots of power. I know people who use stock wire with over 100w output.
You will hear no difference.
Good luck.....
I plan on pushing 80-100 watts to each door. Out of curiosity does anybody know how many watts the factory Premium sound systems is pushing to the speakers?
