?'S on a 2" suspension lift | Ford Explorer Forums
99redXsport
katy, tx
'99 X sport
ok i only want a 2" suspension lift for my 99 X sport 4x2
but i dont want to do the TT thing i here it messes up the joints. and id rather spend the money know and get it done right, then end up fixing something else later.
any web sites or company names and part numbers would help alot and also prices would be nice. thanks
dont know of a 2" lift besides cranking the T-Bars, but you can get 3" with Lift spindles since you are 2wd.
PEACE
your 2wd only thing it will mess up is alignment which is needed after any suspention movement. So up front crank the tortion bars up 2 inches, then do some add-a- leafs in the back plus some warrior shackles and your set.
do you have to do the shackles and the add a leaf or can yo just do the shackles by tghem selves in the back. and the TT in the front.
just the tt in the front and shackles in the back, you dont need the aal also
thanks, when everyone talks about them they always talk about them together so i was just curious. thanks for the info.
It just depends on how level your rig ends up being. Warrior Shackles are only good for about 1.5". If, after doing a 2" TT and Shackles only, the rear may end up being lower than the front (varies depending on how much the rear leafs have sagged).
A lot of people end up doing a AAL/Shackle combo just to bring the rear up level with the front.
its cool i just wont bring up the front that much. thanks though. if i think i need more in the back ill get some aal. thanks man.
I've got a set of AAL's that can be had for very little $.
Jim
how much ofa lift will they give me? and are they just the leafs or is anything else i need to put them on my x
P51DTUG - are your aal still available? I"m interested.
Any chance they come with installation instructions? I've been searching the site for some, but so many search results come back from "add a leaf" or "aal" its hard to find one that describes the process.
I want to order some warrior shackles as well, and do a torsion twist.
i have the money if you want to find the shipping cost my zip code is 77493. just let me know you have my email.
