merc2dogs
- October 22, 2004
- grand rapids Michigan
- 91 eddie
Odd issue, can pull vehicle information and other data, but will rarely pull trouble codes.
Scanner works fine on other Fords from the same year range, Explorers, Rangers other trucks etc.
So tend to think it's something with the sport trac itself.
Any ideas?
Edit for clarification: The scanner worked fine on the sport track before, it's something that just recently happened.
Basically, CEL lit up, checked it, was a O2 sensor, replaced, cleared everything, scanned again, everything worked fine.
Later the CEL lit up again, checked and get 'failure to communicate' nearly every time I check.
Any ideas?
