Bmwz389
- March 1, 2005
- Iowa
- 1992 XLT
Ok so I am about to run some Seafoam through my truck soon because I know it needs it...92 XLT with over 171,000 miles on it =)
So I've read countless threads about Seafoam and where to put it. I know that there are 3 main options (as far as running through vacuum lines goes):
Through the Brake booster line
Through the PCV Valve
Through the Vacuum line under the throttle body
I know where the first to are. The rake booster seems easy to do, but the pcv valve seems really hard to get to, and the line is so small that it looks like it wouldn't even turn upwards to the sky.
I read the infamous Seafoam insertion point (w/ pics), page to page, over and over, and I haven't seen anything about how to run it through the pcv valve or the line under the throttle body.
Here are some pics of what I think is the line:
Here it is from the side:
Now can a pro, or someone who has ran it through the line under the throttle body help me figure out if this is the one.
BUT, if this is the one, I believe I can go buy a connector and some vacuum line, or the use the line from the bi-metal sensor on the sir box (since its not connected to anything anymore) to run it and stick the line inside the bottle and let it suck away =) Does this sound right??
Please help. I'm so close to doing it, and I don't wanna do it wrong...
Thanks in advance guys!
- Brandon
- Brandon
