seat belt broken/can I use one from an 88 F150? | Ford Explorer Forums
maagk
Greensburg, PA
96 Eddie Bauer
Hello, My drivers side seat belt has broken, I called a local reclaim yard and he said that it is a common problem and does not have any. This is the part of the seat belt that is attached to the floor. Our local police are cracking down on seat belts so I need to get this fixed asap as they gave me a warning. Is this hard to do? Thx, maagk
You must use a seatbelt from a like vehicle. Check with a Ford parts expert to see what other Explorer models you can use the seatbelts from. It will probably come down to the 2nd gen. Explorer/Mountaineers from 95-98. Ford changed some colors in 1999, you may be able to use something from as late as 2001. Good luck.
