Selectable Diff Locker 2003 Explorer V8 | Ford Explorer Forums
follett75
Coffs Harbour
2003 Ford Explorer V8
Hi guys, I want to put a selectable diff locker into the rear of 2003 Explorer V8, what do u guys recommend?
Welcome to the Forum!
I moved your post to the Modified section, someone here will help you. :)
The only two selectable lockers that I know of are the
- eaton e locker
- arb air locker
both of which require special setups
the eaton e locker would require a wire ran to the differential in order to engage the locker.
the arb locker would require an air line ran to the differential in order to actuate the locker which in turn you would need a compressor as well as an air tank and a ton of air hose and wiring.
to me the easiest way to go is to get the e locker yet in terms of trail readiness I would say the air locker would be better because it forces you to have a compressor and air tank onboard which is only helpful especially when offroad.
here is a detailed writeup on part numbers as well as options done for the 4th gens which pretty much is the same thing for our generation
http://www.explorerforum.com/forums/showthread.php?t=317166
