SEM Interior Dye | Ford Explorer Forums
SEM Interior Dye
BWilliams
Buffalo, NY (home) // Rochester, NY (school)
'05 XLT Sport
Has anyone had experience with this stuff for the interior? I remember reading about this earlier, but I'll be damned if I could find it.
I have the light grey interior in my truck, now, and I want to pretty much dye the entire interior black, except for the door panel inserts and maybe a few other details. The company says that it works on plastic, vinyl, cloth, leather, and carpet, so I should be able to use one product for pretty much everything.
However, how precise do you have to be with the dye, ie, does it have to be a perfectly even layer, or will it soak into the interior and dye it as long as there is enough sprayed on there. I figure that with black, it would be more of the second, since you can't get any darker once it's black, but I don't want uneven color.
its good stuff
they have a primer that should be used before u paint
id only use it on the plastics as for cloth an carpet its takes way to much for a color change
