Kinserin
- November 3, 2004
- Coaldale, Alberta
- '91
Heya, I've been running my junky 2" lift for awhile, but then I wanted to go bigger because of one of the problems I had on my last outing..
The plan so far has been to swap in a narrowed D44 which is already purchased, Im planning on buying a Detroit Tru-Trac Limited Slip for the front as well as running 4.88 gears for my 35x12.50 TrXuS MTs or a set of BFG MTs, havent quite made up my mind on the meats yet. Rims'll be simple steelies, probably black because Im thinking of blacking out my truck someday, and the rear diff will be a 9" I got from a 1970 F100, which means its already the right length, and already has the 5x5.5 bolt pattern that the D44 has. I'll also be throwing in a Detroit Tru-Trac in the rear (Its my daily driver, and I cant stand my buddies truck that has a locker in the rear) 4.88s... Spring over in the rear more than likely, unless I find a more attractive way to get rid of the shock mounts in the rear.
Overall I think it'll be 6-6.5" of lift all around, I'll be removing my 2" BL, and hopefully I can decide on a design for my front and rear bumpers, but those'll be fabbed after the lift is complete so I can see how much approach I can sacrifice for my winch.
Well, my phone just rang and now I cant think... So, yeah, thats the plan so far, if anyone has any suggestions that'll be cool. Oh, steering... What does everyone else use? The D44 came off a Bronco I believe.. Do you just use Early Bronco steering components?
