casey_wa
- December 31, 2003
- seattle, washington
- 96 eddie bauer
Wow, sure is nice to be able to work on an engine out of the vehicle! ...and that is one heck of a serpentine belt.
I do appreciate the info on the bolts for removing the tensioner. I just replaced the pulley on the tensioner and not the whole set up...along with the upper idler pulley.
I think the 96 Explorer 5.0 is set up differently than the Mountainer. Accessing the tensioner from the top is clearly not an easy task...accessing from the bottom was a piece of cake. I breezed through swapping the belt and tensioner from underneath. I had removed the front wheels and the inside wheel well aprons since I needed to access the plugs to swap out wires. Just one bolt to replace the tensioner pulley and when it was time to install the belt I just used a section of copper pipe over the ratchet handle resting on top of the chassis rail. My hands were free to adjust the belt on all the different pulleys.
Swapping the plug wires is another story...took forever. Course I was being diligent and careful.
I took some digital photos and will get them posted. It is 2245 hours and it has been a long day.
Casey
Casey
