The frame bushing is actually a rubber bushing inside a steel casing, which is pressed into the frame, so just the measurements of the bushing won't help. The frame bushing is not the same as the leaf spring bushing, although they are both just rubber bushings in a casing around a steel tube insert.
If you want a replacement, one of the most economical (not to mention longer lasting than rubber) might be a polyurethane bushing from Energy Suspension. They make black bushings that look stock, they come with the metal sleeve, and are a direct fit.
You can contact most any Energy Suspension dealer and have them order it, or you can go to places online like suspension.com and let them know what you need. They will probably run you about $20-30 for a pair.
You can also just spring for the Hyper-Flex master set, about $120 and it contains poly bushings for the whole vehicle.
