shaking problem at high speeds | Ford Explorer Forums
00Xplorer
'00 XLS
Im getting alot of frontend shaking while driving. The shaking only happens at high speeds around 65+ on the freeway. Dosnt happen all the time but when it does and i turn the steering wheel slightly in either direction it will stop untill its stright again. My front shocks and left front hub are bad. Can those b the problem????...they will get changed next weekend. thanks for any replys...
You might look into tierod ends, control arms/ball joints, and alignment?
I had this problem. I got an alignment and I replaced my tires and struts. It's been fine for me since.
Sounds like tire or drive shaft balance.
