Calvynandhobbs
- February 19, 2007
- Ypsilanti, MI
- 93 Sport 4x4
I know there's a lot of information on rebuilding a shift motor and I plan on rebuilding mine, but I bought one recently from a guy on here to install now and rebuild mine as a spare. when I tried installing it I can't get the triangular shaped rod from the tcase to fit into the hole in the motor. I put 12v to the motor to move the selector piece to be exactly the way the one that came out was. I even tried reinstalling the one I had just removed and it won't go back on either. Do those shafts seen any wear that it could be a little warped? Is there a trick to getting the motor back onto the tcase or is it just a lot of fiddling? Does it help if tcase is in a certain position for the install?
Thanks
Roger
Thanks
Roger
