Shifter Fix | Ford Explorer Forums
Shifter Fix
Creeder
Since I have installed my 3" body lift, my shifter hits the console when I am in second, third, anf reverse. Is there any way of extending the shifter to take care of this problem?
Actually Creeder, there is a fix, go to 4wheelparts.com and go to body lifts, and fords, and there should be a Ranger manual shifter extension, that will work on your explorer as well. It is something like $30 or so, I had to go that route as well, there is no other way to fix it, unless you cut back on the carpet and sheet metal, and move the boot exposing the shifter hole behind the shifter boot. Hope that helps.
