shifter problem | Ford Explorer Forums
shifter problem
lee louther
sacto,ca.
2000 ranger 4.0l 4x4 xlt
02 explorer can't shift out of park
Have you had any issues leading up to this?
Brake light switch or solenoid on the shift linkage may be bad.
check the fuse. i have seen that be the cause of not being able to shift out of park.
also, you can get a poker or screwdriver and push in the manual release on the bottom of the column to get you going until you figure it out.
