jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
I've had the same problem before and did same thing you did, used a jaw puller.man I should have mentioned about the seal couod go in to far, I did that but the motor was on a stand.I had to pull the pan off to get it back out.Ugghh... This is turning into a never-ending disaster....
First, I ended up spending $35 on various electrical connectors, to install the fan. I figured maybe $10, but not $35!
Got the crank bolt at Ford, another $9. Now that I see it, I don't see what is so special about it, that a grade 8 hardware store bolt wouldn't have accomplished, but oh well I have it now.
I found 1 parts store that had the front seal in stock, and they wanted $14 for it! (More on that later)
I tried to locate 2 longer 8mmx1.25 bolts, for the puller, as the ones in the kit were slightly too short. Nobody had them. Oh well, in the end I couldn't of used them anyway... See below:
The real trouble started today. I did discover that I had longer 8mmx1.25 bolts, that came with the ASP pulley. Unfortunately I couldn't get them to thread into the balancer holes. I spent over an hour just trying to figure out what was going on, thinking maybe my ancient truck had different size holes, maybe even standard threads?? No, I finally decided they were the same thread, but they were just badly rusted up, from many years of road spray, salt,etc...
OK, so I'll just run a re-threading die through them, right? The first hole worked ok. On the second, my re-threading tap broke, in the hole. There was enough of a stub sticking out that I could have gotten an easy-out on it, except my smallest one (10mm) was too big.
I thought about using the larger, un-threaded, holes, and just using a bolt, with a nut behind the balancer, but there wasn't enough clearance, and I probably wouldn't have had a bolt long enough anyway. So, now what do I do?
I decided to try a regular 3-jaw puller, with the teeth around the outer edge of the balancer. Yes, it would destroy the rubber, but this thing was junk anyway. It did move the balancer a small amount, before the jaws slipped, and the puller popped off. Wasn't gonna work..... So now what?
Well, normally I wouldn't do this, but as I said, the stock balancer is already junk anyway. I managed to just barely get an air hammer in there, at the right angle, along with a curved chisel. I put the chisel on the back side of the balancer, just inside of the rubber ring, so I was pushing on the inner hub. It worked, fairly easily. My biggest concern at that point was having the balancer pop out unexpectedly, and fall on my head.
Ok, so its out. All's well right? Nope..... I decided to go ahead and change the crank seal. The old one came out easy enough. When I tried to put the new one in, it started to get "****ed" to one side. I get it straightened out, and thought I was good-to-go. When I tried to make sure it was seated all the way in, it went right through, and into the timing cover. I assumed there would be a "stop" built in to the cover, to stop the seal from going through, but apparently not! I was able to fish it back out, but the lip was cut. I can't get another seal until tomorrow, so I'm stuck; losing yet another day....
Oh, and I found that the upper rad hose is leaking, where I inserted the probe for the fan controller. I knew that was a bad idea, but this probe won't work anywhere else. It's too fat to fit in between the fins on the rad, and it's too long for that anyway; at least with a single core rad. Most of the probe would be sticking out the front, and reading cold air temps. I just pulled the hose back off, and jammed some black RTV in there. Hopefully that will seal everything up. I have to be careful not to tighten the hose clamp too much, or it will crush the capillary tube. I have a flex-a-lite controller, with a probe meant to go in the fins, but I was saving that for the Explorer. Plus, I'm not quite sure where it is.
Hopefully, this thing will be running tomorrow. I need to get back out and make some money.
I hate probe sensors, they never seem to work right.don't really understand where you have it at now but sounds like its going to leak.that rad gets hot and under pressure it may blow out.I put a "T" in my heater hose and that's where my sensor is.
Sure your get it all figured out today and be back up and running.hopefully saving you some cash also, udp combined with fan should give you a good noticeable difference.
