Skyjacker 2 inch, and coil spacers? | Ford Explorer Forums
  • Thread starter Thread starter 93 & 96 EB & XLT
  • Start date Start date
9
93 & 96 EB & XLT
I just got the skyjacker 2 inch lift (new coils, and add a leaf) I dont know much about the whole camber/caster thing, I just know I need to get it aligned after the lift. Can I put on the coil spacers too, and still get it aligned right or what/
If you have the Skyjacker lift coils, you may not be able to install the coil spacers and still be able to get it aligned properly. My best friend and I installed just the Skyjacker lift coils on his Ranger and the alignment shop could barely get it within specs. I think, since they have a similar front suspension, this would hold true for an Explorer as well.
ok thanks for that input. I have heard different stuff, so Im trying to get more opinions. I have heard you can, and you cant. I have heard of people doing it, and people that havent. I have heard of people with big lifts like 5.5, and 6, with coil spacers too.
bigger lifts have dropdown brackets...
The spacers will not work with the Skyjacker coils. It would not be alignable...
Yeah, thats what I figured, well thats ok. Maybe one day I will take the 2 inch skyjacker lift, get drop downs for the front, and do a spring over in the rear, that will be cool. Thanks for the info, you guys help right away as usual!
Did you get the skyjacker camber adjusters? You are going to need them even without the spacers.The stock ones will not adjust out far enough...
